Radiomaster Boxer
Hello. I hope I am in the right thread.
While doing the CNC Mod Kit, I unscrewed the retaining rings for the Switches. The Switches fell out. Does it matter the direction of each Switch is UP or DOWN? I know you can put a one position Switch where a two position Switch goes and vice versa.
I would really appreciate any help with this.
soky157
Technicaly it does not matter , but your programing if you have any needs to be adapted if you swap up/down.
You can just check in which position the switch registers as ON (100) and orient it based on that.
You can swap switches and i did that, but the length of the 2 and 3 position cables is not the same. I had to completely un/resolder new wires to swap my 2 and 3 pos switches on the right side. If you order replacement switch sets, these cables are longer i found out after i already did the work in the stock boxer. I have the max version so may differ per model if cable lengths are ok for a swap without too much efford.
Thank you I feel alot better now!
soky157
[-] The following 1 user Likes soky157's post:
  • fpvapnea
Hello,  I followed the suggestion of the previous Poster and used a Multimeter to test positive and negative position of the SA & SD Switches....really helped alot! One last question please. Can some tell me the BOXER comes with the 2 position Switches SA & SD, came with the Positive in Top Position and Negative in bottom position? Also, the 3 position switches Top Positive, Bottom Negative?
I am almost there!  All help is more than appreciated.
  Boxer Toggle Switches Follow up to previous thread question soky157 0 119 14-Feb-2024, 03:28 AM
Last Post: soky157
  Radiomaster Boxer Exit Button soky157 4 292 03-Feb-2024, 11:41 PM
Last Post: soky157
  Accessory Radiomaster Pocket gimbal drop! Bud13420 1 540 03-Jan-2024, 04:17 PM
Last Post: Alfonso Gordon
  Radiomaster TX16s replacement part. Help! drproctor 5 1,948 28-Feb-2021, 07:10 AM
Last Post: Peterthehagrid
