05-Feb-2024, 10:55 PM
the objective of this build is to fly at least 7-9kms out (and back!) utilizing the lightest li-ion pack possible which i guess could be 4S 21700 or 6S 18650. it must have motors spec’d to run on 6S with low enough KV to efficiently operate on 4S also.
SO i am mulling over IF a smallish 6 or 7in build can be accomplished with the following given components:
- lithium-ion pack 21700 or 18650 in whatever cell count to accomplish the task
- apex 7in frame (165g)
- emax eco2 2207 or 2306 1700-1800kv motors to drive 6 or 7in props
my guesstimate for empty weight for this build would be 550g with the 2207 motors which closely matches that of a typical 5in freestyle quad. with the possible heaviest 4S 21700 pack AUW will be 830g. i have read other 5in freestyle quads reaching these AUWs with owners still reporting decent performance as well.
hence i thought the 2207 motors with low 1800kv could still be used for VERY mild acro with smaller 6S lipos and do decent LR with a larger 4S 21700 (or 6S 18650) pack. if asking for acro using 6S would risk toasting the motors then would it be fine for exclusive cruising only? pretty much like the dji mavic with those huge 9in props run by oddly smallish motors.
hoping for the LR folks to chime in…
