26-Aug-2023, 01:22 PM
Recently I replaced a dead FC in my iFlight Chimera 7 with a Matek FC, after which I found that my quad kept showing a rather weak RSSI when connected to my Tango II. For example it would show only 70% in the OSD when the quad was 1m away, then would rapidly drop to under 30% when it was only a few hundred meters away. The Tango 2 would give me voice warnings of critically low reception, while the DJI VTX was still running at 50MB/s. Needless to say I wasn't getting the range I expected from Crossfire. My quad went into failsafe several times, usually less than 1km away, before I found this solution.
Firstly, you need to have your receiver working on 12 channels. Here is a guide on how to do that.
Next, assign the RSSI signal to one of the unused Aux channels. Channel 11 corresponds to Aux7.
To assign the RSSI signal to Ch11/Aux7, do the following:
- Power up the quad and the RC so they connect
- press and hold the MENU button on the RC, select the Crossfire menu, then "XF Nano RX"
- Scroll down until you find "Dst.Ch.11", click on it and scroll until you get "RSSI" and save it.
- In Betaflight, open the Receiver tab. Under "RSSI Channel" Select "Aux7".
- Aux7 should now show the maximum 2000, which corresponds to 100% RSSI
Just send it!
Just send it!
