Betaflight Github questions
Recently I rebuilt my 5" basher.  It was on BF 4.2 with the "cinematic" PID preset from the BF github page.  I had purchased licenses for the ESC to add bi-directional dshot.  Well, this 'NEW" esc just got Blujay and wanted to re-install that same PID setup on 4.2.( had Flight controller issues- so no cli dump), give it a couple packs...update betaflight to maybe 4.4 or so, and compare.
   I was able to locate BF 4.2 on the Github site but could NOT locate the profiles they had before (HD, Freestyle, cinematic).  Does Github "edit" past non relevant "settings" once they become outdated?  if someone does locate these, please post the location... im just curious  why I cant locate them.
(11-Feb-2024, 08:38 PM)Rob Axel Wrote: Recently I rebuilt my 5" basher.  It was on BF 4.2 with the "cinematic" PID preset from the BF github page.  I had purchased licenses for the ESC to add bi-directional dshot.  Well, this 'NEW" esc just got Blujay and wanted to re-install that same PID setup on 4.2.( had Flight controller issues- so no cli dump), give it a couple packs...update betaflight to maybe 4.4 or so, and compare.
The presets are in a different repo: https://github.com/betaflight/firmware-presets
Not sure if was also/already used on 4.2 a current master oldest presets are 4.3, but you could do a clone and check older commits untill you find one that has the 4.2 related presets.
edit: checked out the 1st commit and nothing there that far back. Maybe in 4.2 the presets where in the configurator and not in the repo as the dedicated preset system likely was introduced later. Did you try to check the configurator matching the 4.2 release if it has presets ??
This is where I started..and it flew so well compared to how it used to fly .. I didn’t touch it.. except for adding 6s on 4s motors ..
https://youtu.be/eFTnlhQRCFo?si=upOmueJ1-2exJeGT
At the 5min mark you will see JB show you the PID profile for HD.. they WERE all on the same page.. simple lines to paste into the CLI..
Not a big deal.. but after watching and hearing how much of a difference these made to the base 4.2 version.. maybe the Devs just added it to the final and removed it from the page.. who knows..
I MAY have a cli dump from this quad on a old laptop.. I’ll have to look.. if I find it.. I’ll see how it compares to the base 4.2 tune..
found s couple cli dumps.. 4.2.3 was the "oldest", and i may have found another with 4.3 so maybe I did update it and not realized it... Im Pretty sure when the new version of BF got released the PID settings got changed for the better....
Sorry for wasting your time with this thread...I should be getting stick time in... not pounding keys on a laptop...I was just kinda curious...
we are so close to 4.5 :-)
maybe check bf 4.5 release candidate would be an option either :-)
(12-Feb-2024, 03:48 PM)Rob Axel Wrote: found s couple cli dumps.. 4.2.3 was the "oldest", and i may have found another with 4.3 so maybe I did update it and not realized it... Im Pretty sure when the new version of BF got released the PID settings got changed for the better....
No worries  Rolleyes with current weather laptop time is all i get as well lately
.. per Sir JB.. no need to update to 4.5 unless your serious about “gps return to home”…
I loaded 4.3 and a profile / tune.. configuration wasn’t so bad since I just did it..
Handling was much better.. so much so, I got a little cocky and put it into a tree… so I was unable to check the motors..
I tried using my “rescue quad” to get it down.. and ended up getting TWO quads stuck…30ft. Extension ladder and a 20ft pole with a hook.. and I was able to retrieve both… lost a motor / esc .. have to troubleshoot. After all this.. gonna take a short break, lick my wounds and regroup before proceeding ..
  betaflight config 10.10 RC2 issue Rob Axel 3 286 10-Feb-2024, 01:21 PM
  Betaflight Motor Test Results in SmokeStopper overvoltage LoganFPV 5 251 01-Aug-2023, 11:22 AM
  Prop questions B4tn 15 627 25-Jun-2023, 10:10 PM
  Build T-Motor F7 stack - Betaflight Gyro update frequency 3.2kHz ???? MindBenderFPV 2 3,129 18-Jun-2022, 09:10 AM
  Solved Betaflight 4.3.0 RC3 SoCal_FPV 5 543 17-Feb-2022, 06:30 PM
Last Post: SoCal_FPV
